I just completed the PL install. Not sure if this is stated anywhere else but the simple answer is the metal things on all corners of the 2 boards are NOT rivets.... The boards are stuck to the metal brackets that form the structure because they have been on there for 30+ years. Use a very fine tip screwdriver or knive edge to separate the circuit board from the metal frame when installing the power Logger.. They are not rivets....
