intercooler clean up
michael evans
825
78
28
Louisville, Kentucky
Looking at my intercooler I see that it is oil coated like the intake itself is. Could that be why the intake temperature rose during boost as much as it did ?
What is the best way and what to use to clean it out ?
Hahny
514
155
43
45
Maryland
I used brake cleaner on mine and then followed up with some simple green and I allowed it to soak overnight and washed it out. Just be sure that you allow the intercooler to dry completely. I found that a leaf blower works well for this application. Good luck!
turbo nasty
Turbo Dojo / MNTR
Jul 19, 2001
8,228
429
83
St Paul, MN
Careful with brake and carb cleaners theres many that will hurt the paint. Parts washer (clean solvent) or gas and then hot soapy water followed by a good water flush and you can use the blower side (have a clean filter in can) of the shop vac with a hose hooked to it to dry it out
~JM~
Wrinkled Member
Oct 31, 2007
2,121
509
113
Are you talking about the interior, exterior, or both?
Beware of using Simple Green & Purple Power type of products on aluminum. Some will cause damage. I used low odor mineral spirits to flush out the interior. A trip to the car was should take care of the exterior. Do the outside first, then the inside. Dry the inside with clean air from a shop vac or blow dryer. Beware of any fumes.
  • Like
Reactions: TurboBuRick
michael evans
825
78
28
The inside of it.
~JM~
Wrinkled Member
Oct 31, 2007
2,121
509
113
Purple Power is bad news on aluminum. I ruined a bunch of parts using that stuff.
~JM~
Wrinkled Member
Oct 31, 2007
2,121
509
113
Was that deluted with water or stright ?
Very diluted. Small aluminum parts that were either anodized clear, or clear coated. Soaked in a utility basin type of sink. Later on I noticed the water looked nasty. The parts had been striped of their finish & were chalky/scaly looking/feeling.
Top Bottom
