I was reading my new issue of Muscle Mustangs and Fast Fords (isn't that an oxymoron?
) and saw an article on methanol injection on a blown 5.0 'Stang. It was a kit VERY similar to Julio's (Razor), and used the exact same pump if I'm not mistaken. What suprised me is they had better results on pump 93 and methanol vs. 116 race fuel! If I read correctly, they picked up like 78 horsepower over the 116 because of the cooling effect and the fact the car was not intercooled. I know a lot of members here frown on alky injection and prefer the safety of race fuel, but if I'm reading this correctly, the meth/ pump gas combo is far better at resisting detonation vs. race gas, at least on a non intercooled car. Kinda flies in the face of some of the "common" logic around here, huh?
Julio, I highly reccommend you pick this issue up, there may be a whole new market you're missing out on! The kit in the article was $399, and was semi progressive. Kicked on at 3 psi and was at full blast at 5 psi. Must have had an internal map sensor. Knowing what your current kits include and what you are capable of, I bet you could cut that price by $50.
Just an FYI
Just an FYI
