Did you replace the MAF and cap off the PCV at the same time? If so, then you need to do one at a time and check BLM's to verify if only the MAF or only the PCV is the problem, or possibly both if BLM lowers when you do both checks. From what I know, smoke on initial startup and warmup indicated valve seals. A turbo should blow oil into exhaust no matter what temperature so I'm pretty sure that's not the problem.
Like 87geeinn said, "On initial startup and warm up, the car WILL blow black crud which is just small carbon deposits mixed with condensation that is being blown out as the car warms up."
If the "smoke" out of the exhaust dissapears quickly then it is moisture evaporating, if it carries away until it slowly dissapates into the air then it is really smoke. Think about it as a boiling pot of water(moisture) and campfire smoke(oil). Oil typically burns a bluish color, while moisture burns white.
