is my scan master on crack??
im faster
why am i gettin so many codes???
o the top of my head.
55
54
53
52
44
42
35
33
and a ew more im forgeting.,,, wtf over
its running about the same as iy alwyas does.. maybe even a little better.
if i remember some of them are not even for turbo cars
i mean the car isny runing perfect by any means... just checked. and....
car on not running..
33
42
car on not running after 30 sec.
33
car running at idle
55
54
53
52
44
42
41
35
34
that kinda what i am thinking after reading all that... i will check... in a few min. colors is getting ready to go down... hahaha
scan master is clean.. lol.. its my turbo tweak chip thats making it all weird.. loks like its time for a email... hope he is cool about it
Well, try to unplug the ecm from the pos. side of the battery. You know, the orange wire plug. They may be stored codes.
When i had a 2.0 SM in my car it was reading goofy codes like that, but it was because my chip was for a 2.1 SM.
What version of SM do you have, and what version is your chip set for?
That's why mine was giving me all my MAL codes, since it ran fine i wondered why it was giving me all them funky codes.
Yea, i just checked my old SM readings (when this was happening) and i got ALL of them codes EXSACTLY!
-Adam
i have a 2.0
i have reset the ecm many times
it didnt have the codes i dont think at first after installing the chip
That's why.
Your chip is set for 2.1 SM high update patch.
This will give you goofy readings when using the 2.0 SM.
That was the problem with me, so i gave my borrowed SM back and got a 2.1, and everything's fine now.
Talk to Eric, tell him you want your chip burnt for the 2.0 SM. Wouldnt see why he wouldnt take it back and reburn the ole girl.
-Adam
You can also update the chip inside the scanmaster to make it a 2.1.
Mike L. at Full Throttle sells the updated chip.
Used to be about $35.
If you need or want the high update patch to work.
High speed is the problem, no more upgrade chips for the 2.0 units they are no longer available :(
Mike
