Is there any good online diagrams or detailed pics?
qwic87gn
I've got the motor in the GN torn down to the block, it's been sitting there for just under 3 months and I'm having trouble remembering which bolts go in which hole. Most are easy enough to figure out by running them in, but there is a few that aren't so easy. Also having trouble with exactly which way some brackets go. The pictures I took and labeling things is not cutting it in some areas.
I know it can be put back together by going back and forth. I don't want to rush it(mistakes happen then). But at the same time I would like it back together before something happens and I need the car for transportation.
The only thing I have found is a exploded diagram of the lc2 on gnttype.org. That isn't much help(not clear enough, blurry). Is there a better diagram floating around somewhere?
I'm almost wanting to make a few phone call and have another GN get over just for reference. :mad:
Thanks in advance!
Hmm... why do I get an index list, but when I click on a section, it tells me its missing a .pdf document?
This sounds interesting, I want to download it.
