Lee Thompson
- May 24, 2001
Have a friend with an unopened 87----mods. include THDP (with stock type wastegate), bleeder valve, adjustable reg, 42 lbs. inj and a cold air kit. He had a 49 turbo and running 25 psi (steady) @ 12.12 and 114 mph. We changed out the 49 (It went bad) to a used John Craig 62. Now the boost goes to 25-26 in first but falls to 18 as soon as it shifts to second and stays there all through 3. I have 0 experience with a stock type wastegate. What is happening here? BTW, the puck does not have a great seal as the 62 is used and the sealing area is somewhat pitted. Is this a classic case of boost spike? I am wondering if we have the boost set @ 18 and it is spiking. Kinda afraid to raise the setting any as it might go higher in first.
Need advise from you experts!!!! Thanks
