Keys Stuck In Ignition
NEWCHAPTER
Need Speed
I finally got everything back together , took a small drive to make sure everything works... I pulled back into the garage and shut it off and tried to pull the keys out . This has happened before and usually wiggly giggly of the shifter works but it didnt today.. at least its locked up in the garage any ideas would be appreciated
Patrick is exactly right. Sounds like you had the transmission out maybe?? Check out the shifter linkage, If it looks good (no tweakage) then there's an adjustment on it that should help.
I have also had it happen before to me after I installed a transmission back in and it was the shifter linkage was off a bit. Turn the column and see if the key will come out then.
turned the column and turned the key and it came out.... thanks guys... now I can start installing the alky kit :biggrin:
