Vendor Defendor
Out the window
- Nov 25, 2002
This is kind of a stupid question about turbo’s, I’m still learning about all this stuff, after all I’m used to working on stuff like 350’s, which is what I got my edjamacataion on. Heh, but what’s the point of running anything bigger than stock on the street if you can’t run more than 17-18lbs? I know you can if you run higher octane gas or alcohol you can run more boost, but if you don’t have this, like me, and you can only really turn up the boost at the track, and even then only up to like 22psi which from what I understand the stock turbo is good for… it kind of seems pointless… unless I am missing something big here (which I probably am…). Is there some sort of advantage? Do they spool up faster? I would think 20psi of boost is 20psi of boost. If some one could straiten that out for me, I would appreciate it.
Neil
Neil
