Any input would be greatly appreciated. Heres my setup on the car from what i can see. I bought just like this and it will knock at wot the guy i bought it off of wasnt able to get it right and sold it to me. 87 gn pete tomka cold air intake, what appears to be a ta49 turbo and everything else on the car appears to be stock ic, injectors. fuel reg etc hooked a scanner up to it a took it on the freeway this is what i got when it starts knockin. BLM is 142-145, ect is 187, intergrator is 128 knock signal is yes maf is 128g\s air temp is 54 deg o2 volts 0.15 o2 cc is 6 sparkadvance is 23deg tps is 3.31volts. No i do not have an aftermarket boost gauge i will be getting one next week until then wich way do i turn the adjustable wastegate rod to lower the boost until i get my boost gauge installed i think this is a maijor part of the problem. also after a while of cruising the car can get as hot as 194degrees is this to hot should i install a 160stat? The car has 100 000 miles at 1\2 throttle the car will take off like crazy while cruising on the freeway at wot when the factory boost gauge pegs it will knock if i get out of it and keep the boost out of the red on the factory gauge which i no is unreliable the car is actually pretty damn fast Sorry about the lengthy thread. Any input?
