ok guys i need help bad i have a new motor with about 5000 miles on it, i have been running rotella and i changed the oil every 1500 miles heres my problem i have a low knock thats sounds like its coming from the bottom rear of the motor and it RPM sensitive at idle i dont hear it but if you give the car a blip on the throttle it gets loud and as the motor settles i quits down and i assume it gos way as i dont hear it ive check the converter bolts and its tight im really hopeing its not a rod bolt
