Latest ISAC Software Build
JayC
T6P.Com/TB.com Administrator/Webmaster
Staff member
Its been a while since I posted a build of the ISAC software so I thought I would post the latest one. I believe this is the version that will be shipping with the units. Here's a few of the changes.
- MAP sensor input has been moved external and will now support pressure transducers up to 150PSI.
- RPM scaling is now active for your sliders. Click on the left most RPM cell and enter your low end RPM, click on the right most RPM cell and enter your high RPM and the software automatically rescales your sliders. This is for both boost and alcohol sliders.
- Third channel added to the software which by default will engage with the pump. This is for those kits that use solenoids for preventing leakage. You wont need a separate pressure switch to engage the solenoid as the controller will energize it when the pump engages. Of course, if you're not using a solenoid, you can use that channel for other things.
- We've also added secondary input to the controller which will let you run a separate pressure transducer for controlling boost. This is useful if you're using CO2 to control boost.
- The logging screen has been cleaned up a little.
Take a look and feedback is greatly appreciated.
