Robert Wilson
- May 26, 2001
While trying to decide what offset lifters and pushrod lengths I was going to need for my current project, I had an opportunity to compare 3 types of solid lifters and thought I would share the information.
Viewing from left to right in the picture below, we have shielded foot Crower solids, then Comp Cam solids, and lastly #1241 aluminum top Iskys.
Lifter Weights (set including link bar):
Crower 232.8 grams
Comp 232.62 grams
Isky 219.65 grams
Diameters:
Crower .8416"
Comp .8411"
Isky .8420"
Push Rod Length required (Measured with TA heads on 0153 Block):
Crower 9.270"
Comp 9.270"
Isky 7.800"
I decided to use the Isky lifters in my combo. I first wanted the Isky because my lifter clearance was going to be over .003" with the Comps but, as you can see, I am also getting the benefit of less weight and a 1.470" shorter pushrod.
Special thanks to Kip for the mock up pieces
Crower 232.8 grams
Comp 232.62 grams
Isky 219.65 grams
Diameters:
Crower .8416"
Comp .8411"
Isky .8420"
Crower 9.270"
Comp 9.270"
Isky 7.800"
