slimtastic said:
im not sure i see how a radius on those drain back holes would speed up oil drain back....i mean its all the same gravity.
You serious? Well in that case why not just plug every drainback hole and replace it with a hole the size of a spark plug gap. You think a 1 inch hole in the bottom of a bucket filled with water, wont drain any faster than a 1/4" hole?
You have alot of oil volume thats moving fast, and you cant get it to the pan fast enough at high rpm cause there is nothing pumping it in the return direction. All you can do is assist gravity by opening the holes up. If you cant drain as fast as its being pumped upward, the pan will go dry and your engine go bye bye. I think block oiling mods should be mandatory with anyone going to a high volume pump. As far as blocking the rear return holes goes, I think thats a very bad idea. Acceleration forces the oil toward the rear of the lifter valley. The lifter valley would almost have to totally fill up with oil before it would start draining. Just open up and radius all the holes and you'll be fine. Doing what you're talking about can cause more problems than help. Also, from the factory most oil galleys are drilled with a long drill bit from the front, and then one from the back. But the holes drift as they're being drilled, and they tend to not meet center to center. They can end up VERY far off from one another (where only 1/8" of the holes join), and this can create serious oiling problems. You can have a machine shop use 1 very long drill bit, like a 3/8", and run it all the way through. These totally eliminates the step. Then drill the ends of the galleys bigger, about 3/4" inch in, and tap the ends for 1/4" NPT pipe plugs, to replace the press in ones. Then work the front cover out. You can also drill out the oil feed holes coming out from the galleys, that go into the main webs. Then the holes in the main bearings get opened up to match. Then polish all the casting flash and open up and radius all the return drain holes. Between the polishing and opening those holes up, as well as everything else, you can actually make use of a high volume pump, and you will very unlikely every see an oil starvation issue again. This is the treatment we would do to all our high strung road race motors where a dry sump wasnt allowed. The engines would tear down after 500 miles at WOT, looking brand new.
If you want to re-invent the wheel to reduce windage, you'll end up disappointed. People have explored this stuff to death and its best to just take the advise of the pro-engine builders. Do some block oiling mods and a windage tray and you'll be golden.
