limit of the stock maf sensor?
Cme2fly
WH1 driver
whats the limit of the stock maf sensor? any cars in the low 11's or high 10's with the stock maf sensor, stock ecm, and any name chip? this is assuming all other mods have been done, turbo, IC, piping, etc, etc
need some info asap. thanks
I went 10.69@125.8 last year with the stock MAF, ECM, and Jim Testa chips(11.46@115.8 best on pumpgas)
So far this year I've gone 11.20@120 on pumpgas with the stock MAF, ECM, and chips from turbotweak. No racegas times yet but I hope for 10.50 or better this year.
HTH,
Steve
sorry about off subject a little bit Cme2fly
but what do you guys mean about stock ecm...is there an aftermarket one you can buy?? i thought a chip is all you could do to it....
shawn
maybe they mean that they have a size of injectors that you didnt have to modfy the ecm
Thanks for the replys, shawn, stock ECM means running high Z injectors ie, 50,55,60# injectors..low 11's high 10's is what I'm looking for.:D
Guys have gone 9's with the stock ECM, with the drivers modified for low impedance fuel injectors. Example - Dave Poppe.
These days you can get 60 PPH, high impedance injectors. 60 PPH supports about 720 HP! That's enough to grenade a 109 block.
When someone says non stock ECM, they are generally referring to one of several aftermarket ECMs, such as a FAST unit (i.e. DFI).
The stock MAF has been in the 10s, maybe even quicker, but with cheap, larger MAFs from SBCs and translators available and the stock MAFs being old and unreliable, stock MAFs tend to get replaced along the way.
WE HAVE A 231 STG 1 THAT IS AT 9.84 137. OUR GOAL IS 9.50
STOCK MAF CHIP FROM TURBO TWEAK
ROB
