Anyone have the cliff notes on logging trans pressure with a 200r4 and XFI? Which sensor and location? I would think this is common, and would like to have some advice from experience rather than learn the hard way, as I often do.
It's no different than logging fuel pressure or oil pressure. Use a standard pressure transducer with 5 volt output. Wire the signal into Analog 3 (or 4-8). You can go into your software and label it (File/Analog sensor...). The sensor gains and offsets vary depending on which sensor you're using
