Looking for an RJC 3" DP compatible cat
sd-slider
NOWUFFO
Anyone have a leftover cat that was used for and RJC or other 3" down pipe?
Found out the hard way that expanding a stock cat inlet to 3" doesn't make it any shorter...:(
Looks to be 14" from flange to the end of the inlet.
Let me know if you have anything and how much you want for it.
The good news I;m getting really fast at swapping out downpipes ;)
Eric,
Red Armstrong used to sell 3" cats for the TH downpipe. I don't know if he still sells them but they already have the correct flange on them and sound similar to what you need.
Neal
Eric, I am having a 3" cat made for a RJC DP I just installed, and it should be ready Monday.
It will have the 4 bolt flange to connect to the exhaust and will slide onto the DP.
Eric / Nick, if your need for a cat is to pass smog the aftermarket cats are two way & only legal in states other than CA. you have to have an approved three way cat with the right carb. number. the correct replacement cat with a 4 bolt flange is about $350.00 & comes with a 2.5 " inlet that has to be modified to 3" in order to work. They do make a universal correct cat thats cheaper but doesn't come with the right flange. So unless you have some welding ability this could be a problem. The only good news most smog inspectors are too lazy to check for that so I guess you could take your chances.
I have one that I do not need / use anymore. I think it's total run time is only 3 or 4 hours, as it was only used occasionally and temporarily.
I'll grab a pic and a measurement.
It came from ATR back in the day. Other than that no branding. I imagine ATR sourced them and then welded on a Buick style flange
Eric,
That cat is very similar to the one Red offered. It's a 2 way cat like Lou was describing but should do what you want to. $75 is a good deal, you should buy it.
Neal
Haha only 2 good things about Illinois.....
-no more testing
-E85 on (almost) every corner
but that's it!
Converter is Sold.
thanks Eric will keep you posted on shipping.
