looking for some door and window parts
turboterror
Im needing some parts for my 86 gn. I dont have any weather stripping on the outside or inside of the glass or the felt pads with adjusters that keep the window tight. The door glass just flops around on both windows.
I also need some kind of piece that fits between the edge of the drivers and passengers door glass where it meets the quarter panel on either side. My car is devoid of these. There is a gap when you shut the doors. The cars interior was in pieces when I bought it so I dont know whats there and what isnt but I cant find those parts for sure. If someone might also post a couple of pics of their interior so I can kind of see how it goes together I would be grateful. This is on a t top car.
Thanks in advance for your help. Already you guys have helped me through a vacuum brake conversion, getting my car running,advice on tires sizes and so much more I couldnt have done without your advice/help.
i probably have what you need for cheap, some parts even free, but i parted out the ttop car so i cant take a pic to see what you need. So if u or someone on here can post pics of what you need i will be able to assist you more. I know for sure i dont have the inner and outer window seals but they are still available from the dealer. lmk
Greg
Greg
Do you think you might have those pieces that the door closes against on the driver and passenger sides? they fit between the edge of the door glass and the quarter panel before the opera windows. Im sure I will need some t top parts also. What all might you have?
yes i have some of those parts, but i think there is 2-3 different parts. 1 will be a flat piece of metal about 3 inches wide and the length of the window. i think there is also a channel that screws to that and that hold the seal which should take up your gap u see from the outside. I wont have a good seal u will need to buy that. I will take some pics of the pieces i think u need later today.
Greg
Greg
That would be great Greg, Ill check back with you when I get home from work tonight
