I will first admit I have an exhaust leak...its not super loud but I can hear it pretty good. Would this be enough to drop from 22#'s of boost to around 17-18#'s? I have an external wastegate and I cranked down the spring pressure all the way and even opened up my air regulator all the way going to the top port of the gate. I was hoping this would bring it back up. It didnt.
I just installed alky and I am upset that I cant boost it up to test out the new kit. I plan on changing the gaskets today when I get off of work(felpro 1400's), but I want some suggestions for in case the exhaust leak does not fix my problem. I have had exhaust leaks in the past with other TR's and never noticed a major deduction in boost but then again I was not running the high #'s that I am now.
