Lost oil pressure
GNGAL
86 GN T-Top
Aug 11, 2009
423
76
28
St. Louis, Missouri
www.facebook.com
Driving and lost oil pressure.
White smoke from breather, oil pressure gauge was in the middle of 0 and 25, oil light came on on the cluster.
I checked turbo line and it is not clogged... working on getting that back on after the rain stops....whats my next stuff to check??
Staranded on I55 north bound.. just south of Springfield, Illinois
balanegra
55
0
6
Sounds like you blew a head gasket. Check the dipstick for milky like liquid, check the breather for the same.
TurboBob
Resident mad scientist
Staff member
May 24, 2001
6,112
444
83
Commerce Township, Michigan
sounds pretty dire. do you have any friends with a trailer?
the oil pressure light comes on when the pressure is very, very low. so assuming the car was still running ok, I suspect a broken oil pump, or something like that.
B
GNGAL
86 GN T-Top
Aug 11, 2009
423
76
28
St. Louis, Missouri
www.facebook.com
Thanks... heading to a hotel tonight (via tow truck) in Springfield, Illinois. Going to do more diagnosis once i get checked in.
Oil has a grey tint to it. If it is a head gasket... i have an extra set with me... could do it in the hotel parking lot.... actually. .. wouldnt have a choice.. would have to do it there. Good thing i brought all my tools
balanegra
55
0
6
TurboBob has a good point also. I have seen the roll pin break that fastens the oil pump/cam sensor gear to the shaft. To check, just remove the cam sensor cap, have someone crank the engine. The sensor cup should rotate if the roll pin is good.
pacecarta
MAGNA
Staff member
Aug 1, 2003
9,095
769
113
RIP racewaypark, NJ
oil pump drive gears can also crack and then the shaft cant spin the gear at the end
you have to be under 4psi for the dash idiot light to come on
fast86gn
Texas Moderator
Staff member
Sep 28, 2001
3,255
387
83
Garland,Texas
www.lspbc.org
Nothing like a beautiful women with a great set of tools. Sorry I had to say that. ;) Anyone else from the tour there able to help out?
balanegra
55
0
6
If the engine has cooled down check the water level in the radiator.
robzombie
If you blew a H/G and got coolant in the oil it should read higher than normal on the stick [depending on how long you drove it that way] and it will look white/gray.
Either way you would still have oil pressure unless you emptied the rad of coolant into the crankcase and took out the bearings. You need to be a little more specific, maybe post a pic of the oil on the stick to verify condition.
Check the rad to verify coolant loss or not. If the oil looks like grey mud it's coolant in the oil.
Take the oil filter off and see what comes out and snap a pic of that.
It could very well be an oil pump issue and not a H/G. Just need a little more info to give you an accurate answer.
deezdad
926
240
43
Mendon, Ma
Go easy on posting specifics of your where abouts etc., could be some low lifes reading this. How far is auto zone? Maybe try a cab or uber...
