- May 28, 2001
I posted previously, that when I keyed on, the fan would run on hi. [cold or hot start.]
I disconnected the delay and then only lo speed would come on @ key on.
Bob suggested I unplug the ecm. Did that, still comes on low.
I looked at the relays, and found this goofy looking Bosch on the low fan harness.
As you can see, it has a grnd wire permanently molded to the case. I took the screw out, moved the relay away from the inner fender>>> fan quit.
I then installed a new, 30A Bosch relay. Key on, no fan, engine almost dead cold.
Here's a pic. NE1 know what this is? I don't recall one like that on my last TR.
