May 2, 2004 #1 T the wrath Active Member Joined Sep 29, 2002 Messages 1,343 i just istalled the low fuel light in my 87 gn i doesnt work is there something else i must do to make it work
May 2, 2004 #2 T Topjimmy Member Joined May 24, 2001 Messages 1,001 I installed the module in my car, works fine, comes on at about 1/8th of a tank. No modifications needed. HTH- Jimmy
May 2, 2004 #3 Z zam70 ->ROGUE Joined Aug 6, 2001 Messages 2,731 Mine has to get really low before the fue light comes on - basically on E.
May 2, 2004 #4 G gn1220 Active Member Joined Nov 11, 2001 Messages 1,278 The car has to be darn near out of gas before the light comes on.
May 3, 2004 #6 R rev. 3:11 "BEHOLD! I COME QUICKLY..." Joined Apr 2, 2002 Messages 824 Stoopid kwestchun... Which wa do you align it? In other words where does the nothched end of the circuit board face ?
May 3, 2004 #7 T the wrath Active Member Joined Sep 29, 2002 Messages 1,343 it is only one way you can put the board in
Sep 11, 2004 #8 C cwelk87gn XCELR8S Joined Oct 28, 2003 Messages 1,034 I just installed mine and have a question, is the light supposed to come on when you first turn on the key, like the volt water temp and oil pressure guages do?
Sep 11, 2004 #10 Z zam70 ->ROGUE Joined Aug 6, 2001 Messages 2,731 nope - only when you are almost empty
