First off I'd like to say I'm now an official member of TurboBuick as I just picked up my 87 GN this weekend
Quick list of pertinant mods - girdled motor with je forged pistons, ported stock irons, terry houston downpipe with hooker exhaust, PTE44 @ 16psi 93 octane, TurboTweak chip, art carr tranny with art carr 3000 n/l conv. Has new coil pack, plugs, and wires.
As for the problem, when accelerating from a stop it seems to stutter around and not know what to do until I get going through the RPMs and moving on up. It doesn't do it all the time however, sometimes it's worse sometimes its not bad. It doesn't sound like it's missing though, just stuttering. For example on the interstate it is pretty smooth. It only does this while accelerating from low rpm, whether WOT or part throttle. But once it gets up to 3000+ or so it clears out and runs great up top through all the gears. Even if I try to brake boost from a stop it's stuttering around and can't hold a steady boost or rpm.
The first thing we thought of was the MAF. The car has a new remanufactured autozone special MAF for an 87 GN. Now that tipped me off first as the problem since they seem to be junk from what I've read. However I went ahead and cleaned it with electrical contact cleaner to be safe, as well as the IAT sensor. However there was no change in driveability. Should I go ahead and pick up an LT1/LS1 with a translator to rule this out?
And no I don't have a scantool device just yet, planning to pick up a Scanmaster real soon. I was just hoping you guys could give me advice on where to look until I can scan around and see what everythings doing. I also read somewhere on here some people were having luck with cleaning the tar off the "cooling fan relay" wires or something? Where are those at?
