salvagev6 - I'm basically with ya there. However, there is still the labor to install the $219 LCAs. So how does that work...the new LCAs have the bushings in them? Isn't there labor time to remove the stock bushings? I've been reading posts on how difficult it is to remove the bushings. They're inside the stock LCA, right? Or one takes the LCA out and the bushings are removed from the chassis separately. I'm at the office and away from my car, so I can't check the configuration.
turbo nasty - You say the diff. is incredible. What, the diff. between stock vs. Southside or boxed stock and Southside? What exactly is the difference in feel/performance. I've just installed a motor w/GN1 heads and am making tons of HP, and am having major traction problems. I just received Nitto DR tires, which will obviously help. I've not really having any wheel hop, just loss of traction. Will better LCAs help?
Thanks,
Terry
