It's not a kit. It's off a 4th gen camaro. You need to get all the brackets off the car and where the parking brake cable attaches you need to cut and weld the end of the original lever off the drum brakes to the lever off the new parking brake lever. The bracket off the 4th gen F body that holds the cable in place will be needed to position the cable in the right place/
