MAF placement ??
300kGN
Can the MAF be mounted too close to the turbo inlet? I wasn't going to try to mount it directly to the bell but maybe 4"+- from it.
you can put it there or even direct on the turbo but be sure that the inlet to the maf has some length to it so the fiter isnt in the direct path of the coolant fan or you will have issues
lt1 /ls1 (with translator ) you can put anywhere including in the uppipe which does away with the coolant fan problems
