maf problems
shawnz
I keep getting a code 34 which means mass air sensor.It idles fine and does not stumble when you tap on it.Maf numbers at idle are 6 and 7 motor does not change when you unplug the harnrss.I tried a friends maf from a low mile car and dont get a code.Bumper to bumper car parts can get one for 119.00 canadian with one year warranty.Opinions welcome thanks John
It's prob a bad maf if your friends works on yours.
Make sure it's not vibrating on anything when you install new one, has a lower life when that happens.
Sounds like a bad MAF to me. Can you get any boost, or does it fall over when you try? Personally I wouldn't get a new stock MAF, I would move up to the LS1 MAF + Translator Plus. That's what I did and the driveability increased dramatically.
thanks but the car still seems to run alright but im getting more knock now and its throwing a code
Which is it? Is it running alright, or is it knocking and throwing a code?
Fix the MAF. Skip the replacement OEM and step to the LT1 or LS1 + translator. The rebuild original styles don't last long.
It seems to drive and idle alright but as soom as i reset the ecm it sets code 34.It does not knock until im 20 plus lb of boost im using alky
maf translator
have a original maf on my 87 gn, not running bad , just reading other posts about the translator.
i do race the car a couple of times ayear,
what device do i get? tranlator or translator plus? and what size maf sensor 3", 3.5"
reds pump and reg. 3" thdp, stock turbo and inj. 275/50/15 nittos
car runs 12.40 @108 on cam 2 purple
thanks!
scott
When I did mine I bought the Translator Plus. The only difference it the Translator Plus allows you to change the timing (Which I still have yet to splice in).
I went with a Granatelli Motorsports LS1 MAF, and a solid MAF pipe and Big Mouth Cold Air kit from Mark at BuickGN.com.
I couldn't be happier, everything works like a dream.
