Max Power
  • Thread starter Thread starter 2slow
  • Start date Start date
2slow
Guest
what is the max power on stock block, whats the weakest link, then whats max with girdle,rods,pistons,ect and also what size injectors for te62,3k stall...thanks John
Kind of all of the above at 600 HP. At that level I have heard of just about a failure with each one. I will say it seems crank flex plays heavily in the mix. I imagine if you use a steel crank with a decent reinforced bottom end 700 HP would be do-able as long as you could keep the heads on with 8 bolts. Crap shoot with a production engine after 600 HP regardless.
