Metal Brake Lines
84GNTTYPE
Senior Member
When I was changing the rubber brake line on the front passenger side, the metal line broke due to rust and rot. Is there an easy way to fix this or do I just need to go and get a new line and bend the heck out of it Thanks!
Several choices:
1-fabricate one yourself with straight tube. Requires pipe cutter and flare tools and tube bender.
2-find a good used one at the salvage yard. They are the same for all G-Bodies 78-87
3-order a pre bent stainless steel one from www.classictube.com
Eric Fisher
