I've been reading other posts about people having a miss; so I followed the advice and put on a new Coil Pack + Ignition Module and then a new TPS.
The ignition module gave a slightly smoother idle.
The coil pack seemed to help with some mid-range knock I had.
The TPS took away the knock altogether???? Which of course really surprises me. (.42 at idle, 4.76 WOT)
I like what I've gained, but I still haven't solved the problem I set out to fix. At around 5 psi (part throttle) the car feels like it's missing. It pulsates.
Looking at Direct Scan, everything looks fantastic. All BLM's within 10% of 128 (no vacuum leaks, fuel pressure is good, etc.).
I do have the original MAF, but my numbers look clean from it.
Any ideas?
Any ideas?
