If all are synthetic and even the same brand, mix away! If they were different brands I would worry about different additives reacting with eachother, but I doubt that would even happen.
As far as what the actual viscosity would be? I have no clue! Maybe one of the resident rocket scientists could give you a formula
The "DON"T MIX MOTOR OIL!!!" hysteria arose over people pouring in high-detergent oils into older cars that had never had anything except non-detergent oil...50 YEARS AGO.
When enough high-detergent began flowing through the ND engine, all kinds of gelled oil/dirt residues began de-attaching itself throughout the engine...from the VCs down...through a caked-up lifter valley, eventually arriving in the oil pan, clogging the oil pump pick-up & oil-returns. (What do you think this did to the motor?)
_______________________________________________
Your situation is radically different. Contemporary engines & oils do not have these kinds of compatibility issues.
