More 86/87 wiring diagram questions for the experts
PaulRV6
I am trying to check some wiring connections on my engine harness (which is outside the car) going from the bulkhead spade connector to the various connections on the sensors and ecm. I may be confused about going from the bulkhead connector to the ecm (A6) or CCCI (P), I don't have continuity with the pnk/blk wire which is highlited. I thought the bulkhead plugged into the fusebox and that is where all the power would come from but maybe not. I don't know what the "F" means and the S457 connector but maybe thats where things are missing. I am hoping someone can clarify this for me and give me a better understanding of the connector designations. BTW I also copied the bulkhead connection layout from the caspers website. Also if I go from the D4 connection which is labeled on the bulkhead in have continuity to the "M" term on the CCCI.
Sorry for the length but not sure how else to ask. Thanks
Ok so where's the C437 white connector and where does that go? I don't have anything showing that connector? Thank you
the connector is listing wire terminals by row column , so F- 4 is for powermaster and fan delay relay ,(only wire on the F row )
if your dash harness is from an 84 then there wont be power on that wire
heres the fuseblock connector diagram for 87 turbo
Ok so if not all the 12v power comes from the C100 harness connectors where else can I find where it comes from, ie. C437? What shows it? Thanks
Drop the glove box it's right behind it. The one with the fuzz on it. The black tape is on the pink wire I had to bypass that connector the car kept dying on me when it went intermittent, fun times....
That is awesome, where did you find that. I appreciate the help guys. Hopefully that will answer all my questions.
Paul
Just wondering, looking at the connector layout it shows a barometric press sensor, I didn't think the GN had those? Is that for a different VIN?
Paul
I’d invest in an FSM(free). You can search on here for the links.
Not sure how exact il’ll be do an ‘84, but it’ll give ya a lot to work with.
There are section specific chapters so you can go to the section ya need. Just use Control “F”(if using Winders) & type in what ya need in each section.
Does this look correct for the all connector I have on the harness? According to the wiring diagrams I have the colors are different and slot designations. I guess I'm not sure that is the aldl connector. This is on my 86-87 harness. Thanks again
I suspect that there is another harness btw c437 connector and the ALDL connector? Only assuming this. Can someone confirm? Thanks
None that I can see go through another connector, I don't think that connector has anything to do with the ALDL port.
The ground wire goes to the ALDL from a spice in the harness, the other ALDL wires shown on these pages go straight to the port from C437.
Post up a pic. of the C437 connector and that wiring.
I couldn't find the ALDL connector and thought it was the one I showed above. Here is the c437 connector and nothing plugged into it. Where would I find the ALDL connector? Yes I have those two wiring diagrams.
Mines under the radio where it's supposed to be.
Two row connector with mounting tabs.
You need two black connectors that plug into the white C437 connector A-H and J-R.
