More Oil pressure
  • Thread starter Thread starter Cakes
  • Start date Start date
C
Cakes
Guest
I noticed on my car when fully warm I have 10 psi of oil pressure (LOW :( ) and at 2400 rpm I have around 36 psi(spec says 37 @2400). I do have a stock oil pump woth booster plate from ATR(dont know who makes it) Is there anything I can do to up my oil pressure. The engine has around 52k on it and I had the oil pan off all the bearings looked good for an engine with 52k on it. Thanks for your time and help!
You could try a thicker oil.If you run synthetic try Mobil1 15-50 ,if not synthetic maybe a 20-50 or something.
Cakes
Did you install the boosterplate and set up the gears? the reason i am asking is that i just done mine and set the gears at .003" I hope i have more than 10 psi at idle. I will not know for probably a month or so:( got so much other stuff to do so finding time to work on the TR is slim...........................................Thanks Bob
