My car loves E85
mommasGN
98
8
8
I finally got around to installing my bigger pump and E85 chip. Wow, my car loves it. Feels great across the entire RPM band, I'm assuming this is because of the increased timing. And......Its only $2.20/gal. I love this stuff!
What A/F is everyone targeting? I'm at 23 psi now on a TA49, and at 10.8 to 10.9 a/f. My 60's are maxed out (85% DC). Absolutely zero knock. Ok to turn the boost up?
I don't have a flex fuel sensor. My good friend with a supra gets E85 from the same gas station, and its always in the 70-80% range.
  • Like
Reactions: Zach L.
mommasGN
98
8
8
I would get bigger injectors before upping the boost much more , 80's minimum . Is your new pump hot wired , if not it needs to be . Keep an eye on fuel pressure .
yes, the pump is hotwired. I don't have a permanent FP gauge,. 2 times now since I have made the switch, I have taped my FP gauge to the windshield and drove around....both times, its been on point.
GnJoe87
13
2
3
Minnesota
If you turn up the boost your DC% is going to head north. 85% is as high as most would go. If something goes wrong with your fuel system it doesn't leave much room for correction in closed loop. If your daring and keep a close eye on fuel pressure you can give it a .5 psi bump and see what it does to your DC% . If your fuel pressure drops your injectors are most likely going static or the pump isn't keeping up. If you end up logging knock with e85 something is way off.
dank GN
BlackArts Automotive (661)993-8277
Jan 11, 2009
3,569
423
83
SoCal the high desert
60s are tiny for e85 . 80s are super small aswell imo . I would go with some 160s if you are serious about making power on e85 . Just my opinion.
Top Bottom
