My GN powered GMC S-15
Turbo V6 231
weekend warrior
Jun 14, 2007
326
3
18
Orlando,FL
Looks great, do you have any pictures of how you overcame the k-member, I know there was lots of issues I have seen getting the stock oil pan to fit without modifying the pan or the k-member, I have been wanting to do this in an s-10 extreme for a long time, that was one reason to stop me, any help or pictures would be helpful.
again great looking project
Darryl Carmouche
23
4
3
34
Lancaster,Ca
Sure, I just notched a section out.. & welded in some 1/4” plates ... first time welding so judge me... pan looks close but I cut out a little more ..5EE9B1DE-92E3-4586-9FE8-4762E4619EA9.jpeg65CDF693-D5EA-4758-8599-05A2EF29715D.jpeg
Turbo V6 231
weekend warrior
Jun 14, 2007
326
3
18
Orlando,FL
Sure, I just notched a section out.. & welded in some 1/4” plates ... first time welding so judge me... pan looks close but I cut out a little more ..View attachment 324516View attachment 324517
Welds look fine to me, that's easier then I thought, my project might come sooner than later,lol, hey another question how about the mounts? Did you make custom ones, or did you find aftermarket swap ones? Thanks
Darryl Carmouche
23
4
3
34
Lancaster,Ca
Man finding mounts were hard as shit & no one makes them for the Buick v6 just the 4.3 v6 & all the v8’s. So I made those too from angle iron & flat bar.1608E877-94A2-46E6-AB82-D43A43C73E7F.jpegA3F999C8-2C77-4DC6-BA04-165FAD5A9DCE.jpeg53085DE5-262B-46BE-B402-1042AE54AFD1.jpeg
Turbo V6 231
weekend warrior
Jun 14, 2007
326
3
18
Orlando,FL
Ok, I figured that did a bunch of research, I have seen something similar done before, they look good, the existing mounts on the frame, were those from a 4.3 ? Or was that a 4 cylinder? Or did you put your own body mounts in?
Sorry for the questions, just very interested in this, and you got some good pictures ,thanks
Darryl Carmouche
23
4
3
34
Lancaster,Ca
Np @ all. They are the stock mounts from the 2.8 I pulled out. Glad I can be of some help. I had one guy from here help me w/a few things & everything else I just had to figure out.
Turbo V6 231
weekend warrior
Jun 14, 2007
326
3
18
Orlando,FL
Great thanks last thing,(for now) the Trans mount? Custom? Also rear end is it a GN rear or the s-10 one with posi? Any extra pics would help, I'm good with the wiring, I did a hybrid Rx-7 before, which came out great
Sent from my iPad using Tapatalk
Darryl Carmouche
23
4
3
34
Lancaster,Ca
Get one from advance adapters B.O.P Buick Oldsmobile Pontiac to Chevy. I have done the rear end yet put I plan on pulling a 8.5 out of one of the Chevy blazers , it’ll bolt right up. Post some pics once you start, would like to see your progress.
Turbo V6 231
weekend warrior
Jun 14, 2007
326
3
18
Orlando,FL
Ok will do, so you are not using the 200r4 in your truck? Going 350 or 400?
Thanks (are the blazer ones posi units?)
Turbo V6 231
weekend warrior
Jun 14, 2007
326
3
18
Orlando,FL
Just just curious which code is a v6 and which code is a 5 speed, so I can start looking for one
