Turbo6Smackdown
- Dec 31, 2005
I just threw in some new redline synthetic gear lube with no limited slip friction modifier in it(75/90 ns) in my rear diff, to see if it would help with evening traction out on my tires. Well I was told by several people that it took a little less than two full one quart bottles. Well mine swallowed both of them up without leaking any from the diff plug, and i think it could have taken more too. Do our rear diffs (stock) take 1.8 quarts WITHOUT leaking? or does that mean 1.8 qts is full, and any more would leak out of the fill hole. are they not fully 'full' unless theyre leaking out the fill hole?
And I thought the 'no friction modifier' gear lube would make my rear end chatter around the corners. it didnt one bit. is there something wrong with my rear end?
