Name this turbo!?
Very hard to do. I'm guessing 6776H journal bearing turbo, but can't be 100% sure without official part numbers or measurements of the compressor wheel.
One of two things needs to happen.
1. Pull the turbo to intercooler hose and clamps off, now loosen the backing plate bolts, take off the wastegate actuator, rotate the comp cover up and read the engraved part numbers underneath the compressor cover discharge. It will either have a 600- part number or it may even say 6776H.
2. Take the downpipe off and read the turbine housing part number that's CNC cut on the face of the turbine housing. Will read like THB_-_ _ or THB3-76 as an example.
The compressor cover will also have CNC cut part number on the inside face where the backing plate mates to it. Should say CCH67 or something like that if it's a 67mm turbo.
I would do number 1. option so we can know for sure. The turbine housing also will have the A/R number casted into it, close to the inlet flange.
HTH
Patrick
