NEED Adj. Hobb's Switch ASAP!!!
RUQWKNF27
Needs to be naturally open an be adjustable from say 5-20lbs.. I went to Napa an the guy said he could not guarantee it to be adjustable..It was just listed as a "15lbs NA Hobb's" Anyone got any ideas,or any hobb'slaying around??
Go back to napa and get the hobbs switch, i believe its just a oil pressure sending unit. Pull the rubber tit off and that allen screw inside is the adjustment.
I believe the only difference in them,is their initial setting from the factory.
If its for a home made alky kit ..... http://www.geocities.com/diyalky/
BW
BW
Yes the ones from NAPA are adjustale.
OK I went an ordered a "15lb NA Hobb's" today.. As you say they are adjustable just preset from the factory. Well let's hope so.. I wonder what makes theses go bad theres not much to them..
They didnt have it in stock??????? How about going to the warehouse???
Did you like the link?
BW
