Need longer bolts to bolt on THDP! Any help??
Smokin_GN
Only lil girls ride ponys
Hey fellas....
The stock bolts that connected my exhaust elbow to my exhaust housing are not long enough to bolt on my new 3" THDP. Anybody have a part number for a sligtly longer bolt for completing the job???
Thanks!
Carlos
They are M8 standard pitch thread, yeah I forget the pitch but it's the common one not fine thread.
Anyway measure yours now and get 5mm or 10mm longer whatever you need with allen heads. Stainless is what comes with the THDP. They are sold in MM lengths.
Neverseize on the threads and they should work fine.
I use GM Saturn intake studs and put nuts on them and it's easier to get the pipe on and off when you have to do that.
Those studs have a reverse torx head on them to use a reverse torx socket on them to put them in and out of the car with. :)
Thanks for the info! Went to Orchard Supply and got 4 new bolts!
For anyone who needs the info, here it is...
Stock bolts: M8-1.25-20
Longer bolts for 3" THDP: M8-1.25-30
Im out....to go SPANK some 5.SLOWS this weekend!!
Los
