Need one ( 1 ) door rear "escutcheon"
toofastforyou
2FAST4U
The part I'm looking for is... I think is called "door escutcheon" but not sure... Anyway, it's the moulding on the inside door panel which aligns with the door pull strap (and into which the small square caps to hide the pull strap's bolts go)... I only need one very nice( 1 ) "rear driver side"... or maybe "NOS"?
I'm being told that rears are the same on both side...
Anyone can help?
Thanks,
Claude.
you say rear... what type of sedan are you referencing... or are you just in need of the one piece out of a set ..the one closest to the rear ?
Oops... I should have said that it's for an '87 GN... Sorry... And when I said "rear", I meant that there are two of these mouldings on GN door panels and I need the one which is towards the rear of the car. Hope this clears it up...
Claude.
I know Kirban's sells a set for $190. Maybe you can talk to them and see if the will break a set up or guide you to a provider?
i will see what we got i know we have them but the condition will be the issue ill get back to you sir
No part # but it's the one with the square ends, not angled (or pointed)...
Claude.
Rear are the same part number #20215722
Fronts have different part number: Right Side (passenger) #20215720
Left Side (driver) #20215721
