need quick gasket help
87grandnat
i need to find the gasket that goes between the turbo exhaust port and the header, i removed my turbo and the gasket that was on there was tightened way to much (it was copper) and it was bent all up and broken, i went to GM and they said they were discontinued and i also tried Autozone, i was beginning to think that this gasket wasn't stock (is it?) If anyone knows were i could et one of these gaskets fast, it would be much appreciated.
would the turbo leak, if a gasket wasnt used? If i can't find one i might have to try this, thanks
silicone
use a high heat silicone, either copper or orange. make sure the two surfaces are flat.
No, that gasket is not stock and your turbo should not leak without it.
There wasn't a gasket there from the factory, but SCE makes that gasket in copper. Part number is 4172.
call John Craig at Limit Engineering, ATR, Precision Turbo or Cotton.
so do you guys think that a silicone would work good, or what do you think that the best route would be
and thanks for all the info.
