Gentlemen (and Ladies)
I'm in the process of rebuilding after the horrible destruction of my motor a couple of months ago. Some of you might remember. I had to replace everything except heads and need some guidance on cam selection. Here's what I have so far: 109 block bored .030 over, line honed, Speedpro powerforged pistons with plasma moly rings, Billet center mains, stock ported heads w/ three angle valve job, stock crank turned .010, Clevite 77 rod and cam bearings. I bought a Federal Mogul stock rebuild kit that included a stock cam and lifters but I'm not sure if that one is good enough. I'm not trying to run in the 10s but I want to have a good platform to build on in the future. My machinist thinks I should go with a Dutweiller cam to "wake it up a little". Do you guys think it's worth the extra expense, $300, for a car that will probably never see the track?? If not what cam is best for street use??
Also I have upgraded to a hotwired Walbro 340 and will upgrade injectors and chip when the motor goes back in. However I'll have to stick with the stock turbo til my wife gets over the shock of the cost of this rebuild!!! What do you guys think? Any comments or suggestions are very welcome. Sorry for the long post.
