Need some help here!
turbov6joe
Signal 1 J-12
What would cause all of the "ignition" locations on the main fuse block to be dead? Are they fused together? Are they fused at all? Can they "blow" independently of one another?
What's odd is the car runs fine, the "battery" terminal is hot, and I havn't found any blown fuses...WTF:confused:
Ignition locations are "dead" when the key is off. The BATT locations should be hot all the time as well as the cig location.
I shouldn't assume that you guys know that I know the obvious...yes the ignition was in the "on" position....any other ideas?
Can't say for sure. I had 2 of 4 that started out hot. I pluged in an alky kit to 1 of them and it went cold. I switched it to the other one and it went cold as well??? Now I have it running into the battery terminal and am turning it off at the knob....have to remember to turn it back on! Back to my original post, are these terminals fused other then through the fuable link?
