turbo81malibu
- Mar 24, 2007
what is the bare minimum needed to get it running, what sensors need to be used, and i have an 87 wiring harness i'm using, what did you do with the fuse panel connection, are you using a separate fuse panel? also, do i use the original wiring for starting the car or does it need to be hooked up to the ecm as well. thanks for any help.
