WHATS UP GUYS...been a lil while..see we got some new members in the hot air community...thats great to see!!!!
also see a few members gone...take care crazygn...hate to see ya go. hey wheres herb....and reds hotair you out there..fjm still modding that ride....ha ha..just a big hello to ya!!!and the rest of the guys
well tuners heres my problem..i need some help..heres the combo to refresh ya and maybe an update of a thing or two....
85 3.8 turbo..30 over trws
107 t cam and valvesprings
30# inj...adj reg...homemade 3" cold air and 14 kn...stock turbo
87 coilpack conversion new wires and cr43ts at 35
okay so been running the stock chip for a while and dialing in the car the best i can..got to run pretty strong
with about 15# boost..38# line off basically no knock or very little knock if any o2 ok lil rich in the high eights..low nines..i think i have a quirky inj..i will work on that as i go along but my throttle response is still good with the tps and iac i had it set to..40..481wot..iac was 25-27 so
i had pte burn me a chip..put in today and boost sky rocketed to near 20 and knocked near 10 degrees..adjust the rod back to the point where it just holds the wg tight and boost is still upwards of 15-16 and knock was as most 4degress i uped the fp to 40 which i didnt really want to do..it helped but i dont think it needs so much fp due to the fact it created a slight tipin stumble which i pulled my hair out to
try and fix so with that i cant turn boost down anymore and it seems to spool up much better now i need some suggestions before i send the chip back
which is probably what youll say... so any suggestions..or other info needed let me know ...sorry so long...and thanks vinny
