So one would think that going from 2 Bar MAP to 3 Bar Map would cause the factory gauge to show less than actual boost. Not the case with this one..
I T'd the vac/boost line to an external gauge and left the factory gauge as is. Now the factory gauge shows boost just above idle and max boost when the aftermarket analog gauge shows about 10-12 pounds. Any info on why this occurs? Both gauges pick up the vac/boost tube right off of the map side of the throttle body metal tube, pretty much where everyone taps the T in.
