Theres two extra line fitting holes' one maybe a 5/8 the other 3/8' A total of 6 holes are in the back of the rad tank: lower rad hose' overflow' 2 oil cooler & the two unknown' as it sits in the car & two on the front side for the trans cooler lines. the extra top one goes into the rad. the lower looks like it runs into the oil cooler in the radiator' I dont know if it flows into the oil cooler though? It dont look like it does? Could this be used for a extra coolant cooler. Would it flow? heres the part # on the radiator AC/Delco #88959435' it also has a RV sticker on it. Im looking for someway to maybe use this if I could find out its intended use. If coolant flows against the oil cooler in the tank as I suspect' this could be a good thing for the oil & coolant temp!
