Dr. Jeckel
- Jul 29, 2003
Well I am running 17-18 psi with no knock and O2's in the 810 to 825 range the whole way with 43psi static fuel pressure. I run 91 octane with 100% alky spray. I am about to replace the timing gear and chain along with replacing the valve springs with comp springs in the very near future.
My question is how much more boost can I run with the 30# injectors. Is it safe to say that if I don't see anything under 780 on my O2's and still have no knock then I would be fine? i know that O2's aren't the best judge but would this be a good judge of how much boost I can run?
Thanks James.
Thanks James.
