New Axles
trbodon21
I need a new set of axles becasue my stock passenger side axle is bent. I am going to keep my current rear end with the same stock gears (3.42). My set up is below. I was thinking to just get the Moser 28 spline stock replacements. Any suggestions on other axles out there or will these axles be adequate? Thanks
What happened to bend the axle???
If you are going to change the posi unit out I would go the 30 spine Eaton Posi route and get moser 30 spline axles, go through it and slap a girdle on it and call it good.
8.5 with 30 spline will handle high 10's all day.
Its actually been slightly bent for awhile, I just never got around to it, but with the new engine rebuild I don't want to take any chances. I wasn't going to make any modifications to the posi. I was just going to put the 28 spline mosers in, but you think I should change the posi? I've seen a few guys go 10's with the rear end set up and they seem to have no problems, but is this not a good idea to take the stock posi this far?
