s3dcollier
- Jun 14, 2004
Hi, new to the Buick Turbos, have always wanted one, now I got one. Purchased an 87 Buick T-Type, had a little bit of a bad idle, was told that it was the exhaust leak when I bought it, but the guy supplied the repaired Header (Drivers side) to fix it. We'll I have since replaced that and ended up welding the original due to the one he gave me having some warpage on the outlet. Any way I have a small ticking sound (small leak now) however the idle still hasn't gotten any better. I have a scan tool on the dash and this is what I see, however the gntype.org is down so I am stuck on viewable documentation on this car.
Here's what I have:
RPM - jumps 775-825 at idle
TPS - .42 - .44
IAC - 64 - 65
CC - changes from 177, 194, 210....
nal - 13
AF - 06 - 05
L8 - 38 - 41
Bat - 13.6
Int - 129 - 141
BL - 125
CLT - 148 - 160
ATS - 97
I have cleaned out the throutle body, cleaned the IAC, replaced all vacuum lines, it has a new gas filter, new plugs, wires.
Car gets up and goes, sometimes chokes when first started and given gas in gear to go. I have noticed 2 bent fins on the turbo fan going into the turbo that I don't think is related to this issue. Car shifts hard from 1st to 2nd and chirps tires. I need to fix the idle issue first, would the bent fins be a bad thing to leave as is for a while? Not sure if the turbo outlet hose being blown half off caused this fin bending or not, the fan doesn't seem to have much play in it. Any help would be great. Thanks
Scott
s3dcollier@earthlink.net
Here's what I have:
TPS - .42 - .44
IAC - 64 - 65
nal - 13
AF - 06 - 05
L8 - 38 - 41
Bat - 13.6
Int - 129 - 141
BL - 125
CLT - 148 - 160
ATS - 97
Scott
